when injectors go bad at 20psi
chrism
Post by chrism »
guess this explains the low compression in cylinder 2
gol10dr1
Post by gol10dr1 »
GOOOOOOOOOOOOOOO. more tuning please :)
itruns
Post by itruns »
Been there. My daughter drove my wife turbo Volvo that I had played with, and when a heater hose broke on the highway, she drove it until it stopped. I used muractic acid to get the slagged Alm. off the cly. wall, dropped in a new piston and rings, and buttoned it up... Ran great. I hope yours isn't more serious. Be sure to check that Exh. Valve.
What injectors/FP were you running at 20 psi?
Bill in MN
Post by Bill in MN »
Ouch! That reminds me of a lot of sled engines I've cooked over the years and in particular one that my buddy turbocharged. 210hp out of a 780cc 2 stroke was great.....when it ran. Man, tuning was a bitch with carbs and no electronics to help out. He finally fried the turbine and gave up on it last winter.
What happened. Did the injector break apart?
Tjn182
Post by Tjn182 »
Yummy! Thats why I'm not making any plans to run high boost!
[Edit by Tjn182 on [TIME]1108137526[/TIME]]
chrism
Post by chrism »
[QUOTE="itruns"]Been there. My daughter drove my wife turbo Volvo that I had played with, and when a heater hose broke on the highway, she drove it until it stopped. I used muractic acid to get the slagged Alm. off the cly. wall, dropped in a new piston and rings, and buttoned it up... Ran great. I hope yours isn't more serious. Be sure to check that Exh. Valve.
What injectors/FP were you running at 20 psi? [/QUOTE]
naa not too serious. i scored a set of Ross forged pistons on ebay last year which need about .002 more clearance in the cylinders, so a bit of honeing to get a scuff or two out, and the old junk is gonna be right back in business. already gave the head a look, the valves in that cylinder look ok, although i'll pull it apart, and give it a look, and relap all the valves. i was running 36# injectors to ~90PSI. not pushing too hard on them, ehh?
:D
gona pop some more appropiatly sized 50# injectors in this time. lets see if i can brain-fuck the motronic into ideling with them!!
BMWJustin
Post by BMWJustin »
Ouch, that sucks. You've fixed worse though... good luck.
Justin
