Im considering installing Megasquirt before i install the turbo setup.
Can you just hook the wires that connect to each Fuel Injector to a switch? So that u can control if the fuel injectors are Connected to the Stock ECU or the Megasquirt? Cuz id like a way to get back to stock setup quickly and easily.
And How might someone Have a Similar Switch for Ingnition, TO flip between Mega and Stock control,
Thanks alot for your time,
PS: Whats considered Max "Safe" Boost, non-intercooled e34 m30(ARP Studs), But with full fuel and spark control?
