Timing belt kit source HELP
Someone please send me a link to a whole kit supposedly there’s Continental kits out there but I can’t find any someone please send me a link.
Re: Timing belt kit source HELP
All you need is the belt and tensioner. Just find the best price and order them.
Mine either came from Pelican or FCPEuro, don't recall which. No kit, just a belt and a tensioner. I did the water pump while I was in there since one of the bolts is blocked by the belt. The Continental belt was out of stock at the time, so I ended up with a Febi Bilstein belt instead.
There's one (and only one) on clearance for $15 plus shipping: https://www.eeuroparts.com/Parts/75316/ ... 531033810/
pretty sure thats the same brand tensioner I used. Make sure you find the plastic sleeve for the pivot bolt before re-using the crummy original or you'll find the sleeve after you have put it all back together.
