I must be insane
Posted: Jul 09, 2018 11:26 PM
Background: I'm the maintainer of audifans.com, the founder and former owner of TDIparts.com (now IDparts.com) and many VW TDIs, current owner of an E30, and crazy enough to have also recently bought an Alfa Romeo.
Completely randomly, I came across a 524td at a local auction. I started researching it and came across the BAT listing https://bringatrailer.com/listing/1985-bmw-524td-2/ and read the comments about these cars. Suddenly I checked the VIN and realized - this is the same car. The car apparently went from Florida to NY, and somehow ended up in San Francisco. I put in a bid and it was accepted.
Drove the car home today (some prayer was involved, I'll explain why).
Car took a long time to start, even allowing for the glow plug light to come on which shouldn't be needed since it's 70+ degrees here.
Got it out on the road, noticed the steering is super heavy (possibly PS bypassed?) and the brake pedal responds but seems harder than it should (possibly brake pressure accumulator?)
Acceleration from a standstill is OK but the engine seems to bog down when you give it more than just a tad of throttle, and people behind me weren't super happy.
I did get it up to 70, seems when it got through the gears it was a bit better, but it definitely had an issue going up hills.
On the overhead panel, warning lights are lit for injection, fuel filter, and coolant (coolant level seems ok).
My plan is to change the oil and filter, service the transmission, change the fuel filter. I have a feeling the turbo isn't coming on at all, and there may be a valve that actuates the turbo like on the TDI engines?
On the plus side, the car is mostly rust free, super clean inside, and still has 48k miles and change (and yes, the miles are legit).
I'm not sure what I plan to do with the car, but the first step is to get this thing running correctly.
