how many bolts hold the injection pump?
Posted: Feb 05, 2018 3:46 PM
by gadget73
OK this is going to sound really dumb, but how many bolts do I need to loosen in order to adjust the timing on the injection pump? The Ford book shows 2 on the timing cover and two that appear to be used to hold the bracket to the rear end of the pump. Sticky up at the top mentions 2 on the cover and 3 on the bracket. Pics of a Bosch VE pump show 3 on the timing cover side.
I have loosened all 4 that Ford mentions and the pump will not move. Not sure if I'm missing a bolt, or if its just seized into the timing cover. This is the VE mechanical pump, not the electronic one.
Re: how many bolts hold the injection pump?
Posted: Feb 12, 2018 8:39 AM
by gadget73
I guess I'm the only idiot that can't get his injection pump to move?
Mostly I just want a sanity check to see if I'm missing a bolt or if the pump is seized in the front cover.
Posted: Feb 12, 2018 9:23 AM
by Kyle in NO
There are VERY few 524td owners who frequent the board, and even fewer who can answer your question. The Lincoln info should apply to your pump.
Posted: Feb 14, 2018 9:38 AM
by gadget73
Kinda figured that, but I was hoping someone else had done this. At this point I'll just assume its seized into the front cover and plan on leaving it alone since it doesn't feel like moving and I don't feel like breaking anything. I was hoping to improve cold starts, but the reality is I don't plan to drive this thing in winter, and it kicks off fine when its warmer or I use the block heater.
Glow plugs are on the list to check too. They appear to have been changed at some point but since I have no idea what the maintenance history is, I can't guess how long ago that was.
