I have an 84 m106 bottom end with the original HD. It has a pulley on the damper, and 2 more pulleys that bolt on in front. I have an 60-2 HD from a b35 that I want to install to trigger my MS, but it doesn't have the pulley on the HD. Does any one know if a three belt pulley is available?
tia
marc
3 belt pulley for b35 damper
Re: 3 belt pulley for b35 damper
What happened to the pulley. Did it fall off? I have not seen a HD without the pulley.
The one I have doesn't have a pulley. I haven't checked the bolt pattern yet. I hope it's the right one.
Does anyone know the right year and model, or better yet the part #, for the correct damper(60-2) that will bolt to my m30 crank, that has the pulley? I've tried bmw oem website, but I'm having trouble finding model that shows the 60-2 HD.
11231722723 I have a couple.
Thanks man!
I appreciate the help. I don't know what HD I have. It was supposed to be for a b35,but apparently it's not. I was surprised the bmw oem shows the old style HD with the one pin, even with the new style part #.
They don't really update the diagrams for such similar parts, just change the number in the chart. There should be one groove on the balancer for the water pump and alternator. Good luck!
