Ms2 is great once you get all the bugs sorted but you made the right decision by sending it out, i made the mistake of building mine and after spending 50+ hours diagnosing a bad vr signal, i had to finally send it out to someone who knew the board well. Turned out to be a faulty transistor and a short. only cost $80 to have shipped and fixed.tschultz wrote:After some further testing:
I seem to have injector pulse as I do get fuel smell and wet on the spark plugs after cranking.
I confirmed 12v power on green lead to coil. I confirmed fuel pump operation with the test mode.
I just tried the coil in test mode and was not able to get a spark from the main coil lead in any test mode setting. Coil set to 'one' and all possible Coils (A-F).
I imagine I need to look at something on the board but I am really not sure where to start. The hardware manual is jibberish to me...
EDIT: Peter at PF tuning thinks the board or harness has issues after I mentioned the test mode not working. Going to send him the board to check it out.
After seeing what you have gone through with trying to get your arfs on target and fuel issues sorted, it makes me happy to see you switching to ms2. Now you can tune all those parameters with only a few clicks. Only thing left is to get the electronic boost controller setup.
