Introducing Jim's custom Alpina B7!
Looks like the turbo has water cooling, interesting. I would cover the intake pipe from the intercooler to the TB with some type of heat shielding. I bet that exhaust pipe from the turbo gets really hot and the intake pipe is very close to it.
Is he running a TEC3 system in this car? If so, I would love to have a copy of the BIN file for reference for my application.
How about mounting the coils here -
This will reduce the length of the wires, keep the coils cool and clean up the engine compartment some.
Is that is a WB O2 sensor? If so it will fail in short order due to location. WB O2 sensors need to be a minimum of 18" from the turbo exhaust. They can not take over a EGT of 1300 F and or over 900 F at the housing measured at the bung. Innovate Motorsports has a heat sink that can be used to fix this condition, its $85 though. Check this web site for some excellent tips on the install and running of WB O2 sensors -
http://www.innovatemotorsports.com/resources/lm101.php
Todd, did you do the work on this car? Great work! Lots of challenges overcome I am sure.
[Edit by Duke M535Ti on [TIME]1108375962[/TIME]]
Many thanks to Todd for posting the pictures/thread. One of these days I'll figure it out for myself and post more.
The intake manifold that Alpina made is just that...no internal W/A intercooler. The unit A/A unit up front is a recent upgrade...a 3.5 in core, 6x17 (cut down from a length of 34.) It should flow around 1100 cfm.
Good idea on the heat shielding, I'll have to add that to the list. The system is a Tec-II, which I believe has compatability with later models. I'd love to be able to relocate the control unit to your location, but with the Tec-II, it a real estate issue...the coil packs sit on top of the control unit and are not separable. The tune is still a bit rough though, but should be a good starting point if you don't have anything else. I'll email the latest files.
The O2 sensor (narrow) is basically serving as a plug. Not sure how hot it gets at that location, but better safe than sorry...next time, I'll use the other bung downstream of the downpipe. The Turbo is a Garrett GT-35/40, and its internals are water-cooled.
Had I been smart about it, I would have take picures of the exhaust manifold before it was installed/coated. Its a work of art. Built in three pieces, v-band clamps holding it together. Yes, getting to the spark plugs is no easy task...alot of disassembly.
Jim
Jim
gt 35/40??!??!?! that is nuts!!!! could you possibly send me that bin file too. i am going to do a tec 3 on my turbo 535. email is gol10DR1@AOL.COM
